2010 VW Passat 2.0T engine Codes P0491 and P2014
Need some help.
I just finished replacing water pump on my 2010 Passat with a 2.0T engine. The good news is the water pump is not leaking anymore!!!!!
After replacing the pump I got the following codes (P0491 and P2014).
I know one code is related to the secondary air injection pump and the other to the intake (flap not operating properly).
Would anyone please let me know the location of the secondary air injection pump. What should I do to fix those issues.
I am planning to go to the junk yard tomorrow so please let me know what should I get from a donor car so I can fix those issues.
Thank you for your help
What were those error codes scanned with a generic scanner?
Thread approved.
Thread approved.
