2004 Passat Coolant Help
Old Aug 14, 2012 | 12:09 AM
92929292's Avatar
Default 2004 Passat Coolant Help
Hey guys - I have a 2004 Passat GLS that has been good to me over the years but having a slight trouble. The coolant tank appear to have 3 holes which 2 is pointed toward the front of the car while the third is pointing to ground which is located more toward back of the engine. Problem is, the car is overheating and steaming due to spraying of coolant as soon as the engine tries to cool itself. I think the problem is the third hole of the coolant tank doesn't have a rubber pipe attached to it so the coolant just sprays/leaks whenever the system is turned on. The tube I think is located toward the back of the engine but I can't find it easily. Any suggestions without taking to a shop and getting charged with an automatic $100 fee? Thanks!
Old Aug 14, 2012 | 05:05 AM
I'm not sure which expansion tank you have fitted on your model therefore I don't know where this third pipe should be fitted. Obviously this pipe needs to connect to something.
See if you can find an image on Google images?
Old Aug 16, 2012 | 03:41 AM
Byroner's Avatar
hi
you need to visually check the engine for coolant leaks.be sure to check around the water pump/...if you have no leaks,then it may in fact be a bad thermostat..replace the thermostat
Alex5357aa
Nov 1, 2012 12:38 PM
Evgeniy
Jan 8, 2012 12:20 PM
Aug 16, 2011 04:25 AM
humphreycharles2000@
Nov 18, 2008 10:47 PM
virginVWdude
Dec 18, 2007 06:51 PM
