Will aftermarket CAT set off my check engine light?
probably, ive seen this talked about before and you can have it put in. they say if you have the sensor in and it throws a CEL, you can put a washer on the threads to back the sensor out a little and it apparently helps. not certain though never done this myself
-good luck
-good luck
-good luck
-good luck
Twoods12
Nov 19, 2010 07:55 AM
meagnash
Oct 26, 2010 02:30 PM
