Whats are the fuses underneath the hood (by the battery) for?
Old Jun 29, 2008 | 08:31 PM
Timetogetill7's Avatar
Member
Default Whats are the fuses underneath the hood (by the battery) for?
There are two slots and one fuse is in (20 amp...i know what its for now) and one is empty.
Whats the empty slot used for? Cruise control?
97 VW Jetta 4 cylinder 2.0
Old Jun 29, 2008 | 10:13 PM
Jrailer's Avatar
Default RE: Whats are the fuses underneath the hood (by the battery) for?
one is for coolingfan a/c
no oncruse control it is in the main fuse box
Old Jun 30, 2008 | 12:44 PM
Member
Yeah thats the one I knew about (cooling fan) and I figured the cruise control was in the main fuse box.
So what's the other slot for? Is it supposed to be empty on purpose?
Thanks.
Old Jun 30, 2008 | 09:53 PM
woody1's Avatar
Member
alot of times thay use the same fuse box on different cars to save money. it may be for some acsesery on some other car. but idono.
if its empty and everything works i say dont worry bout it.
but i know if u r anything like me u will
Old Jul 2, 2008 | 11:39 PM
Member
Its not in the main fuse box.
It's near the coolant and the battery underneath the hood.
Completely seperate from the main fuse box located under the steering wheel.
Thanks anyways.
Old Jul 4, 2008 | 10:07 AM
Jrailer's Avatar
yes they do use the aux fuse box on the battery on diffrent modles
some do fill all three spots and some dont
Old Jul 5, 2008 | 02:35 PM
  #7
Member
Ok. Thanks.
Two spots..not three though.
Old Feb 10, 2021 | 10:16 AM
  #8
Wanda Granado's Avatar
Default What is a fuses box called ? Mine started to smoke...
What is that fuses box called? Mine started to smoke? And dose it run to the alternator too?
Mar 6, 2012 07:28 PM
rossah
Jun 25, 2011 06:45 AM
Feb 4, 2011 11:45 PM
CrazyScott
May 30, 2009 12:20 PM
kradschutzen2
Jan 8, 2007 11:25 AM
