Wagon Owners Help!
Old May 26, 2009 | 12:18 AM
jordankersten's Avatar
Member
Default Wagon Owners Help!
So I think my '02 Jetta Wagon CCM has been modified to disable the seatbelt chime and also to "pop" the hatch like it were a trunk on a non-wagon car. I have a VagCom cable on its way and I need to figure out what to do when I get it. What code to I need to change to get my CCM back to normal and what do I need to change it to? Can any Wagon owners with a VAGCOM confirm their codes? Thanks!!
Old May 26, 2009 | 08:19 AM
racerx002's Avatar
Sorry, for a while now I seem to be the only one answering questions. If you go to http://www.ross-tech.com/ you will find the right program for your wagon and you will be able to enter central locking or the comfort module and reset or program it.
Old May 26, 2009 | 09:43 AM
Member
Correct me if I am wrong, but doesn't the RossTech site only provide the soft coding? I believe what I need to change is in the long coding, specifically byte2 bit3. I know that Vagcom 701.1 has the long coding option and also has boxes to check and uncheck for each bit. Does version 409 and 311 have this option as well? If so, I am good. If not, I need to find the long coding for my Wagon.
Old May 30, 2009 | 10:34 AM
racerx002's Avatar
The old free versions are free but don't do what you need them to do.
jnolte01
Jun 15, 2008 10:29 AM
jnolte01
Jun 12, 2008 07:15 PM
jnolte01
Jun 12, 2008 02:35 PM
jnolte01
Jun 12, 2008 02:34 PM
jnolte01
Jun 12, 2008 02:31 PM
