Turning Off Low Tire Pressure Light on 2017 Jetta
Old Jul 27, 2017 | 07:10 PM
whitey ford's Avatar
Default Turning Off Low Tire Pressure Light on 2017 Jetta
Turn ignition on, without starting, and push the (!) button inside the glovebox, top left, and hold until audible tone. DONE!
Start vehicle and check your work.
Old Jul 28, 2017 | 06:28 AM
You only press the SET button in the glovebox when you have changed the tyre pressures so the ABS sensors (if you have an indirect TPMS system) can recalibrate. Direct TPMS uses pressure sensors in each wheel.
You need to find someone with VAG-COM\VCDS to do a full AutoScan and check the system out, post any error codes found?
Old Jul 29, 2017 | 01:39 PM
I respectfully disagree! Got tires rotated and they filled to 32 psi instead of 36 psi as specified by drives door label. Got the (!) on the way back. Filled tires up to specification and reset the light.
Just trying to help others who may just need to reset low tire indicator (!) light after a low tire pressure occurrence.
Very quick takes 8 seconds!
Old Jul 30, 2017 | 07:10 AM
Why do you disagree with what I said its the same as what you say?
whitey ford
Jul 30, 2017 07:13 AM
domingo
Feb 7, 2009 05:02 PM
JL
Mar 27, 2008 09:57 AM
terrapin
Feb 6, 2007 04:13 PM
