Trouble Shifting into 1st
Old Aug 26, 2012 | 07:15 PM
madjak30's Avatar
Question Trouble Shifting into 1st
I've tried the search and scanning through the threads...not finding anyone with similar issues.
I just bought a 1999 VW Jetta for my daughters to learn to drive in...picked it up cheap...$1000...but there are a few known issues with the car...the check engine light is on (previous owner said it was a failing sensor...I'm okay with that), the right side mirror needs replacing (auto wreckers will have plenty), e-brake cable is broken (again, no problem)...but the one thing that is worrying me is that it is difficult to get it into 1st gear. The car starts & runs quite nicely and it shifts easy (although the shifter is a little sloppy), but when you come to a stop at a light or a stop sign, getting the car to go back into 1st is a pain in the butt...you think you have it in 1st and when it is time to go, you realize it is in 3rd...fart around a bit to try to get 1st, sometimes you are lucky and it slips in, other times I just grab 2nd and slip the clutch...not good...
I'm just wondering if this is a common issue that has an easy fix, or is this something that will require pulling the trans? Again that isn't a huge deal since there are many of these cars in the wreckers, but I'm hoping it is a linkage adjustment or a known wear item...
Thanks for any help...I will be going to pick up a Haynes manual tomorrow for the car which will help.
I'll take some pics of the "Silver Bullet" and post up next time...
Later.
khayes23
Nov 28, 2013 08:34 AM
dirtykurte
Aug 4, 2010 10:18 PM
tamvervan
Mar 1, 2008 05:43 AM
jodievw
Oct 7, 2006 04:47 PM
