trouble code 1296
Cooling system malfunction. I'm new to VW, but I'm going to guess that you need to replace the coolant temperature sensor AND the thermostat. If you let it go, you could break down the plastic impeller in your water pump and end up nuking your engine.
kettlesing
Jan 11, 2014 07:23 PM
1296, 2000, code, code1296, codigo, dtc, jetta, obd, s, trouble, troubleshooting, turbo, volkswagen, volkswagon, vw
