transmission swap??
Old Feb 24, 2009 | 04:34 PM
xzacattakx's Avatar
Exclamation transmission swap??
i have a 1999.5 mk4 and the transmission needs to be replaced i found theres 5 different trannsmission codes for the 5 speed with a 2.0 is it a must to get the right code or is there a couple i can use cuz i dont know...and i need to find the code still so where do i look for that at???...can i just give the manufacture my vin and have them tell me?
Old Feb 24, 2009 | 05:27 PM
dfwjetta98's Avatar
they should be able to tell u everything about the car by the vin.. i know ford can..
Old Feb 24, 2009 | 06:16 PM
dozanti's Avatar
Member
look in the trunk under the mat by the spare tire. I believe you can find the codes somewhere around there. Also check the tags on the inside of the driver door jam and the door as well. I dont exactly remember where it is located but the trunk is a good place to start
kylewatson89
Aug 23, 2009 10:06 PM
werewolfsburg
Jan 19, 2009 06:48 PM
jonwilliams775
Dec 10, 2008 08:54 PM
damas
Oct 3, 2006 12:28 AM
Tony_K83
Sep 10, 2006 07:25 PM
