Transmission Problems
Old Oct 28, 2006 | 12:59 PM
Guardian's Avatar
Default Transmission Problems
1996 Jetta GLS 2.0 litre. When accelerating from a cold start the transmission slips and then somtimes the first major shift is rough. After the car warms this sluggishness seams to disappear? Is this related to my Dash board transmission indicator not lighting up or is this an electrical issue. Does anyone have any suggetions.
Thanks
Old Oct 29, 2006 | 11:57 PM
tomctx's Avatar
Default RE: Transmission Problems
Sounds like you've lost some fluid. Might want to check for leaks.
Old Oct 31, 2006 | 12:15 PM
toledotom's Avatar
Check for low tramsmission fluid and probably the WRONG type of fluid installed. Very critical on VW's, also maybe your screen is plugged not allowing the proper pressure to allow the transmission to shift, this is frequent on an older car. The fluid will thin out do to the engine heat and transmission fluid being warmed up by the trans cooler in front of your radiator.
Old Jan 1, 2007 | 09:45 AM
ndenn002's Avatar
check for leaks then change fluid
see if problem still exhists
is it a manual?
It might be 1st gear burining out
Old Jan 1, 2007 | 01:48 PM
kinky19777's Avatar
K check this out everyones right here.....possible wrong weight fluid or low fluid all that stuff.. 1st n 2nd synchro's going which are notorious......BUTTTTTTTTTTTTT If you do do anything JUST check the fluid level..My thoughts of it being a 96 is that it probably has more than a 120000 on it and the 5 speeds arent cheap-Hell even automatics...If you change the fluid there is a posibility you ill disturb whats going on (ever heard of people getting their fluids replaced with a new screen and then the car burns up a tranny? its because all that caked up stuff after its changed floods the new screen and does more harm than good)....Just drive it ...Unless you know a transmission mechanic PERSONALLY. $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$
Old Jan 2, 2007 | 03:18 PM
ndenn002's Avatar
Disassembly
1. Remove electrical connector from back-up light switch housing.
2. Remove nut (B) and balance weight (A) from gear selector cable attachment.
3. Remove gear selector cable from gear selector lever.
4. Disconnect gate selector cable from actuating arm/relay lever (C) by lifting lug in direction of (arrow).
5.Remove 2 bolts securing back up light switch housing (D) and remove housing.
6. Remove self-locking nut (7) and back-up light switch cam sleeve (6).
7.Remove gearshift lever (12).
8. Remove selector shaft housing attachment bolts (arrows). Note: tap housing lightly with brass or plastic mallet to loosen.
9. Remove selector shaft with housing from transmission.
Modification
1. Enlarge both selector shaft housing attachment holes to 9 mm (approx. 23/64 in.).
2. Reinstall selector shaft with housing using sealant AMV 188 200 03 or equivalent, then adjust according to one of the following conditions:
Vibration or knocking from 1st or 3rd gear: Turn housing right (clockwise as far as possible). Vibration or knocking from 2nd or 4th gear: Turn housing left (counter clockwise as far as possible). Torque bolts to 25 Nm. (18-ft. lb.).
Installation
1. Reinstall gearshift lever.
2. Reinstall back-up light switch cam sleeve (always use a new self-locking nut). Torque nut to 25 Nm. (18-ft. lb.).
3. Reinstall gate selector cable to actuating arm/relay lever by lifting lug (C) in direction of (arrow).
4. Reconnect gear selector cable to gear selector lever (position cable pivot in center of slot on selector lever).
5. Reinstall balance weight (A).
6. Reinstall back-up light switch housing (D).
7. Reinstall back-up light switch electrical connector.
8. Road test the vehicle, making sure the vibration and knocking is gone
this is the diissammbleely....i can't spell of the shifter it might be simpler than you thought..................just a guess
Old Jan 2, 2007 | 03:21 PM
  #7
ndenn002's Avatar
I couldn't of said it better than kinky1977,
but if you know tranny's go on ebay they are pretty cheap...........comparing to pro shops
Onechriso
Aug 31, 2010 01:17 AM
sorin1307
Jul 5, 2010 04:53 AM
JGress
Jun 25, 2009 07:46 PM
libertyh
Apr 27, 2007 02:47 AM
aracos66
Sep 18, 2006 01:45 PM
