timing chain or belt?
Old Oct 13, 2008 | 11:48 PM
dbaseballs's Avatar
Default timing chain or belt?
I have an 03 vw jetta gli with the 24v vr6 does it have a timing chain or a timing belt?
Old Oct 14, 2008 | 10:32 AM
dbaseballs's Avatar
Default RE: timing chain or belt?
well the reason i ask is cause my auto teacher said it was a chain my mechanic said it was a belt, and if you looking in the oil fill opening you can see a chain right there
Old Oct 14, 2008 | 02:23 PM
Jrailer's Avatar
vr6 is chain it runs on the inner end of the motor between the engine and trans
you need to pull the trans out to do a full timing chain job
Old Oct 20, 2008 | 04:36 PM
gscgabe08's Avatar
Member
so i herd that if u have a timing chain that u shudnt worry about it as much as the belt & that it outlasts the motor. is that true? if not, how often shud u change the chain? (00 jetta glx vr6)
Old Oct 20, 2008 | 10:10 PM
Jrailer's Avatar
true you can get allot of life out of a chain and you can here them as they get worn
noquacks
Jan 28, 2013 04:37 PM
Xanadu
Oct 23, 2007 06:43 PM
Xanadu
Oct 22, 2007 03:41 PM
mattrod68
Jan 27, 2007 02:57 AM
jmbsk8er83
Apr 22, 2006 09:19 AM
