-   -   Sunroof drain - Yep... this thread again (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/sunroof-drain-yep-thread-again-35408/)
Luieburger Nov 5, 2012 12:59 PM
Hello all,
I encountered the wet passenger floor. Read all the ways to fix the problem, tested my front right drain and found that it was blocked. I cleared the block, but in the process I removed the nipple from the frame, which pulled the hose out from the back of the nipple.
What's the best way to get in the back and line that hose up with the back of the nipple? I've tried using a wire to line it up. It sorta works but water still leaks down the inside of the frame. I feel like the hose is mostly line up, but not optimally placed to catch all of the water.
Any suggestions for how to get that lined up? I really need access to the back of that space.
Thanks!
Keithuk Nov 5, 2012 01:43 PM
1 Attachment(s)
Welcome to the forum. Attachment 2953
It has been talked about before.
https://volkswagenforum.com/forum/vo...y-jetta-35284/
Luieburger Nov 5, 2012 02:07 PM
Yes I've read through those threads already. My problem is no longer a blockage. My problem is getting the drain hose lined up with the nipple. I'm trying to get the existing tube re-aligned. I'm not putting in a new tube unless I determine that the current tube is cut somewhere.
