Solenoid sensor problem
Old Apr 17, 2012 | 10:35 PM
dcom5's Avatar
Default Solenoid sensor problem
After I changed out the transmission fluif and filter,I still experiencing slipping when shifting from 2nd to 3rd,Then test with my U585 OBDII Code Scanner,it appeard code P0762- Solenoid Sensor stuck ON.Is it mean I should change the solenoid sensor?Thank you in advance.
Old Apr 18, 2012 | 05:17 AM
That all the info that I have.
VAG Error Code: 17146
EOBD II Error Code: P0762
Fault Location:
Shift solenoid (SS) C - Stuck on
Possible Cause:
Wiring.
Shift solenoid (SS).
As taken from my Free EOBD II Error Codes software
JazzJam
Nov 22, 2023 04:28 AM
PowerAddict
Apr 6, 2011 09:08 PM
whitewolf8
Feb 11, 2009 02:55 PM
photoguy
Dec 1, 2006 02:57 AM
exojj
Feb 4, 2006 08:58 PM
