rear disc brakes help!!!
Old 09-03-2006 | 08:37 PM
alexgchavez's Avatar
Default rear disc brakes help!!!
hey guys i have a 2000 jetta im changing my rear disc brakes and rotors. ive already installed the new rotors but im having a hard time pushing the piston on the caliper back in so the pads will fit. ive already broken two of the tools used to push the pistons back in so i guess im missing something and one have some good advice?
Old 09-07-2006 | 06:12 PM
Jsd's Avatar
Jsd
Default RE: rear disc brakes help!!!
Use a large set of channel lock pliars. That should do the trick. Brute force required lol
Old 09-07-2006 | 11:13 PM
Punkmunkey's Avatar
DId u take the cap of the brake fluid resevoir?
Old 09-10-2009 | 12:48 AM
matimar30's Avatar
i hope you didn't get a c clamp and press it open.
rent or buy(best investment i made) a disc brake caliper service kit.
the piston has to be turned to open it. you shouldn't have to force anything. if so somethings wrong. if you are going to reuse the disc either get it machined or if it's smooth then lightly sand out the shine with a very fine sand paper. and don't forget to take some brake fluid out of your resevoir, otherwise you'll get that nasty fluid everywhere.
fyi with the front discs just use a large c clamp and it'll compress.
03-15-2011 12:35 AM
manalo07
03-04-2010 09:34 AM
AdidasCU
07-09-2009 03:41 PM
jetta182
03-23-2007 05:52 PM
moe.ron
12-02-2006 01:24 PM
Quick Reply: rear disc brakes help!!!
