P1582 (idle adaption at limit) trouble code
Old Sep 19, 2008 | 11:22 PM
moparkid440ci's Avatar
Default P1582 (idle adaption at limit) trouble code
MY friend has a '97 Jetta, 2.0l. I scanned his car because it had a check engine light and the P1582 (idle adaption at limit) fault code came up. So I took the throttle body off, cleaned it and put it back on. I started the car, cleared the code. After the car was started again, the code came back on, and the car's idle now fluxuates up and down at startup and when in neutral,which didn'toccurr before I took TB off and reinstalled it. Is there a computer procedure that needs to be done, like a remap of the throttlebody, or no. Im used to working on older mopars, not newer VW's so if anyone can help, I'D appreciate it.
Old Sep 20, 2008 | 01:24 PM
bagel's Avatar
Default RE: P1582 (idle adaption at limit) trouble code
remap the throttle body. also you need to reset the computer.
picasso
May 24, 2010 10:15 AM
CHABRIO
Feb 10, 2009 11:03 PM
wolverine127
Jun 21, 2007 06:50 PM
stickyguy
Jun 11, 2007 12:22 AM
bobando
Oct 3, 2006 03:17 PM
