over heating issue
Old 03-04-2008 | 10:10 PM
VdubMa's Avatar
Member
Default over heating issue
I went in to the garage to fix my over heating issues in my 04 1.8t, the guy said it was a censor. So he put in a new one, iv been driveing around and the engine heat goes up when im doing 80 on the highway. Whats most likely the problem? Does this occur when you hit centain mileage?
Thanks
Old 03-11-2008 | 07:24 PM
bagel's Avatar
Default RE: over heating issue
uh, no. Not supposed to, but does it stablilize or does it rise while driving??
Old 03-11-2008 | 07:35 PM
cwsteen's Avatar
I have an 02 Jetta GL that had the same issue. It was the water pump. Because the water pump is plastic it broke apart and caused the engine to overheat. This is a common issue with VW with higher miles.
Hope this helps.
Old 03-13-2008 | 08:42 PM
Jrailer's Avatar
water pump
markkk1965
05-03-2007 10:46 AM
sive ick
02-01-2007 05:53 PM
blackedout01
01-05-2007 11:28 PM
markkk1965
02-08-2006 09:30 PM
markkk1965
02-06-2006 07:31 PM
