noob with a problem
Old Sep 8, 2009 | 08:50 AM
danb's Avatar
Default noob with a problem
hey guys i have just bought a 1996 jetta. OK so when i bought it the battery was dead and the steering wheel was locked and wouldn't unlock, leading to the ignition being locked. So i was told to stick a battery in it and then it would all unlock and so on, well i did that and the wheel and ignition is still locked up.
I believe it has something to do with the alarm system, can anybody shoot me some help here on it?
Old Sep 9, 2009 | 01:34 PM
tEnZaGLI's Avatar
factory alarm or aftermarket? dont matter if you want it disabled, take to an alarm company or find the brain of the alarm and there should be a splice into the starter kill. Just bypass the starter kill and reattach the factory ignition wire back together
Old Sep 11, 2009 | 02:11 AM
gosgirl's Avatar
I don't know.
Old Sep 14, 2009 | 05:27 PM
tEnZaGLI's Avatar
boot gos girl she just advertising dvds,
Old Dec 27, 2011 | 07:03 PM
Wcrazydaisy's Avatar
Default Help meeeee
Hay my car starts but it shuts off immediately afterward and has a key and a car on the dash soooo frustrating seems like a security issue can anyone give helpful hints volkswagon said bring it in we will fix it but what they don't get is it won't go at all shuts off immediately after it starts
Old Dec 27, 2011 | 07:10 PM
Default Help meeee somebody
My car won't start the immobilized thing on the dash is on can't bring it to the dealer cause it won't stay going. Going to goo crazy tried everything gotta be something I'm missing any suggestions on a reset
Old Dec 29, 2011 | 02:00 PM
  #7
You don't say which model or year of car you have, presumably a Jetta if you've posted in the Jetta section?
Yes you have an immobilizer problem which is common. What have you been doing to start the immobilizer off, have you changed the car battery?
There is a simple trick that works about 15% of the time. Disconnect both battery cables and join them together for a few seconds to discharge any capacitors in the system.. Reconnect the battery and turn the ignition on for anywhere between 15 and 60 minutes then try and start it.
Other than that ship it off to a dealer.
Old Dec 29, 2011 | 04:23 PM
  #8
vwvic's Avatar
You should be able to unlock the steering shaft with the key.
The same way you unlock any other steering.
Otherwise , you have a problem with in the cloumn or related parts or the key.
Are sure you got the right key and you are doing things correctly to unlock the steering.
The whole column can be removed from the car,and also the steering shaft for inspection .
Your dealer maybe able to verify if you got the correct key.
Old Dec 29, 2011 | 04:28 PM
  #9
vwvic's Avatar
You don't say , so assuming it is jetta with 2.0l gas,
You may just have a major intake leak.
Check the hose from intake to the brake boaster first.
Make sure is not disconnected or leaking some place.
Fast
Oct 2, 2010 03:49 AM
pr1mo
Nov 10, 2007 06:41 PM
03passit
Jul 12, 2007 10:54 AM
99JettaTDI
Jun 6, 2006 06:14 PM
novistang
May 30, 2006 02:19 AM
