noise while turning
Old Oct 10, 2008 | 12:06 PM
roxsgirl's Avatar
Member
Default noise while turning
lately when in low speeds, usually taking off or backing up and when turning my car makes a low vibrating/grinding noise. i thought in the beginning it might have just been the wheels hitting the well or something but its slowly getting worse and a longer of a noise. i asked someone the other day and they said something in the line of the steering and to check my fluids. has anyone experienced this before? if so, if whatever part it is goes out, is it costly to fix?
Old Oct 10, 2008 | 01:33 PM
racerx002's Avatar
Default RE: noise while turning
If your power steering fluid is full it's more than likely the p/s pump. If there is fluid leaking by the wheel it could be your power steering rack which would be very costly. Does it get harder to steer the more you turn the wheel?
Old Oct 10, 2008 | 03:00 PM
roxsgirl's Avatar
Member
i havent checked the fluid level yet...and i dont see any fluids leaking anywhere from the car...and for sure the car is not hard to turn when it makes that noise...it just makes me feel trashy. LoL
Old Oct 10, 2008 | 08:12 PM
Jrailer's Avatar
wheel bearing?
Old Oct 12, 2008 | 08:05 PM
roxsgirl's Avatar
Member
whew okay...so i was low on fluid...filled that sucker up...hoping i didnt damage anything by driving it...eek! ::fingers crossed::
Old Oct 13, 2008 | 02:00 PM
bagel's Avatar
Did you fill it ALL the way up?? There's a max line on the dipstick, fill it up a bit past there and you'll be fine. I'm not sure what would happen, if anything, if you filled it to the brim, but the max line is there for a reason.
Old Oct 14, 2008 | 01:50 PM
  #7
roxsgirl's Avatar
Member
yeah its filled to the max line...the guy at kragen asked if i had a leak and im pretty sure i dont. how often should the power steering fluid be filled?! ive never filled it before in any other car...it just seems like one of those fluids that really never gets used.
Jan 20, 2011 01:48 AM
Oct 27, 2010 03:24 AM
daniellagraub
Oct 23, 2010 12:00 PM
mikemac
Jun 12, 2007 09:58 PM
pRoZzAk
May 4, 2007 06:47 AM
