No power to driver side low beam
Hi everyone,
I have a 2014 Jetta and the low beam headlight on the driver side is out. I replaced the bulb and checked ALL the fuses and none are out. I used a test light to check the plug for the headlight bulb and it is not getting power. Any suggestions?
First posts should be made in the introduction section else someone who has had the same problem doesn't need to join this forum they just read what has been posted.
That applies to your problem as it could be a free fix without doing an intro.
Recheck all fuses do you have a good fuse and relay layout diagram?
The other thing is have you replaced the headlight bulb with an original or are you trying to fit an LED bulb?
You need to do a lot of checking with a multimeter.
I checked ALL the fuses both in the engine bay and at the dash and all were good. I noticed today that the daytime running light on the same side is out also. I also checked power at the plug for the headlight that's out, and there is no power coming to the headlight on that side. Also, replacing bulb with direct replacement, not doing LED.
