No INTERIOR LIGHTS! HELP
Old Aug 22, 2009 | 09:01 PM
cshort's Avatar
Default No INTERIOR LIGHTS! HELP
I have a 2003 Jetta, the interior lights are not working. No dash board lights, no radio or climate control lights. Also the buttons on the doors are not working. I just put a new lighting control switch. The door lights and dome lights all work. I have checked all of the fuse.
Old Sep 7, 2009 | 01:01 AM
lamborghini1900's Avatar
Did this happen right after you put in the new lighting control switch, or did you do that to try to fix the problem?
I know that you said that you already checked all of the fuses, but check them again. It might not be the fuse that you think it is, if it is one that is on the same circuit it could cause multiple problems. Once I had my power door locks, interior lights, alarm, and radio all stop working from just the interior lights fuse. Recheck ALL of them. All I can think of is that it is a fuse.
rangiep38
Sep 18, 2008 09:38 AM
Redsand187
Jun 27, 2008 04:03 PM
mikemac
Jun 12, 2007 09:58 PM
asloly
May 10, 2007 07:37 PM
nevercatchme
Nov 29, 2006 11:43 PM
