Need Help/ Electrical problem !!
Old Oct 26, 2006 | 09:57 AM
gsxr1100's Avatar
Default Need Help/ Electrical problem !!
I have a 97-GLX Jetta VR-6. Problem is with the brake lights. The brake lights work fine during the day but, at night, when I turn the headlight switch to the "on" position, not only do the tail lights come on but, also the brake lights, and they stay on !! I believe there is a short in the circuit somewhere. Has anyone had this problem or have any ideas on how to resolve this matter? THANKS IN ADVANCE TO ALL THAT REPLY !!
Old Oct 26, 2006 | 07:24 PM
bagel's Avatar
Default RE: Need Help/ Electrical problem !!
Is there any caution lights on in the dash??
Old Oct 27, 2006 | 08:25 AM
gsxr1100's Avatar
No, there are no warning lights of any kind. Thanks for your reply!
Old Dec 31, 2006 | 05:08 PM
ndenn002's Avatar
check the relay maybe the relay is bad.
Old Jan 2, 2007 | 10:56 PM
ndenn002's Avatar
also check all of your fuses and i'm pretty sure you've blown a few or a few are on the vurge..............
Old Jan 5, 2007 | 11:11 PM
jonyjetta's Avatar
DENN IS RIGHT ....CHECK FUSES ...THE BOX.....AND RELAYS.....BURNED CONTACT PINS ON THE BOX CREATE ALL KINDS OF PROBLEMS...SO DO LOOSE FUSES
Old Feb 10, 2011 | 07:18 PM
  #7
CRMIE1's Avatar
Omg i got a 95 gl and same thing except i my turns stay solid with lights on.....cant figure it out changed turn signal switch and head light switch still not working ...if you find a solution please let me know................tks....
user 70982082409
May 27, 2015 07:51 AM
sk8nnc16
Jun 11, 2010 06:21 PM
Toadmanor
Oct 15, 2009 08:49 PM
ezpcent
Jul 6, 2006 09:52 PM
Giovanni
Jul 5, 2006 11:50 PM
