MK4 Jetta, Heater GONE
Old Dec 28, 2012 | 09:39 AM
ReeSe's Avatar
Default MK4 Jetta, Heater GONE
Hi guys,
I own a 2003 diesel jetta with 160K miles. Yesterday it was snowing...almost 2 ft of snow in 12h. I got into my car started her up, engine reached full temp and then...NO HEAT!
I know the foam on the mix door has a tendency to break or the heater core can be clogged but I use my car every day and it worked fine until yesterday. On Wednesday night heater was blowing very hot and on Thursday morning it's just cold air! And by cold I don't mean cool I mean COLD right from outside...
Things tend to wear out before they break, it happened so suddenly that I don't believe it's the blend door(also,there is no foam coming out of anywhere). Is there a sensor that can prevent the car from heating?
The temperature dial seems a little easier to turn than before, I'm going to remove the center console and foot wells to check the cable is still doing it's work and if there is a sensor to check as well i would like to know.
Also, my temp control dials are not illuminated at night. I don't think there's any relation but you never know until you know...
Old Jan 11, 2013 | 12:46 AM
mr_mk4's Avatar
Hey,
I don't own a Diesel, but I do have a few gasoline MK4's with the 2.0 8v. I can tell you if it was the heater core there would be tell tale signs way before losing heat (e.g: burning coolant smell, or leaking coolant into cabin from in behind dash). The fact that it just stopped and the **** is easier to turn leads me to believe you should looks at the controls that direct coolant into the heater core.
Old Jan 11, 2013 | 05:30 AM
ReeSe's Avatar
Thanks for the info!
in fact I solved the problem a couple of days ago and i was waiting for warmer weather to permanently fix it and post a few pictures. There is a kind of lever that goes into the hvac unit and moves the blend door. The lever had just poped out of its bracket...it was a 10 min fix! I'm going to replace the lever later this week and put everything back in place hopefully i will be good for another 10 years haha.
Old Jan 21, 2013 | 10:24 AM
wabbit's Avatar
Member
In the future try taking a look here: http://www.parts4euro.com/DCShop/index.php?cPath=1
It will help you for sure and also save you some cash
Old Jan 26, 2013 | 03:21 AM
Ambrosemartin's Avatar
Member
Mk4 jetta do powerful performance on the market. It built by a new looks with a protected design. The engine management system is batter than his old car system and that's give a good mileage on the road.
Buellxb
May 5, 2007 05:21 PM
jord_pug106
Mar 19, 2007 04:47 PM
wbstein
Dec 29, 2006 02:52 AM
eurodynamics inc
Jun 28, 2006 04:59 AM
Eddyspeeder
Jun 20, 2006 04:50 PM
