Jetta won't start-special warm/hot Eng.
Old Nov 23, 2008 | 07:59 PM
marcilui's Avatar
Default Jetta won't start-special warm/hot Eng.
Hi! I am happy to find you guys.
I read a lot on this forum as a guest, but I couldn’t find a solution for my problem.
I bought 1 week ago a 92 Jetta 1.8L, automatic and after 3 days to running perfect, the car start more and more difficult. Sometimes start when is cold, but after running for a while, with de engine warm/hot, won’t start again. Leave it for 1 hour and –probably- start.
I have no more ideas what to do. What I did already: replace the distributor cap and sparkplug wires new sparkplugs, replace coil, knock sensor and TCI-H(transistorized/ignition control unit).Also I checked both electric fuel pumps which are working good.
I want to mention that after the car start(if and when –just random), it is running amazing, idle-ing perfect, but when I turn it off.....won’t start again....maybe after it cool down.
I have one more thing to do, in my opinion, to replace the Computer-Digifant II....Should I do this, or you guys have any other suggestion before my last try?
Thanks a lot, I will appreciate your help.
Old Nov 23, 2008 | 10:45 PM
Jrailer's Avatar
Default RE: Jetta won't start-special warm/hot Eng.
try a temp sensor for the ecu not the guage
Old Nov 24, 2008 | 12:34 AM
dbaseballs's Avatar
is it carbuerated or fuel injected?? if its a carb it might have to do with that
Old Nov 24, 2008 | 02:16 PM
Jrailer's Avatar
it is fuel injected
vw didnt have any jettas carburated
only early rabbits had carbs
Old Nov 25, 2008 | 10:42 AM
marcilui's Avatar
Thanks a lot.
I replaced both temp sensor andthe problem is solved.
Old Nov 25, 2008 | 05:25 PM
Jrailer's Avatar
no problem
rudler
Jun 2, 2014 08:31 AM
dleib
Sep 2, 2013 04:45 PM
centerline
Jan 18, 2011 03:04 PM
Jym
Aug 22, 2009 08:40 AM
ZIPS DIESEL
Nov 4, 2005 04:11 PM
