Intermittent smoke problems, '00 Jetta GLS
My car has some serious problems. After driving it for 30-45 minutes it will just start billowing smoke from the exhaust pipe. And I mean a LOT of smoke; I can hardly see out the back window when this happens. I lose a little bit of power, but the car keeps going. If I keep driving, it will stop after a little while, but usually I'll pull over and turn the engine off for a few minutes, then keep going and everything seems fine. I've noticed that this usually happens when I'm accelerating up hill, but I can't be 100% sure that it's not just completely random. Also, the transmission slips a little going into 3rd gear. I had to have the transmission replaced at around 96k mi. because I has having MAJOR transmission problems (slipping, and eventually not shifting at all.) But it started slipping again shortly after that, so I think the mechanic put a bandaid on it and told me he replaced it when he didn't. Or maybe he swapped it out with a used trans. from a junk yard. I donno. I was living 900 miles away from where I am now when I had the work done, so I can't bring it back to be looked at again. The thing that gets me is that if this were a cracked gasket or seal that was letting coolant or oil into the cylinders, wouldn't it smoke like that all the time instead of just randomly? Help!
drummr8
Nov 3, 2011 06:46 PM
Mar 1, 2011 04:54 AM
