Help with Vento (Jetta)
Old Jul 15, 2012 | 06:32 PM
lintywaver's Avatar
Default Help with Vento (Jetta)
Just bought a '97 Vento with 1.9 TDI 66KW/90 HP engine. RPMs are running about 2500 to 2800 at 60 km/h. Is this normal?
Old Jul 16, 2012 | 05:42 AM
applegot's Avatar
Wait! Wait! Before buying have you checked online its prices and its features. I think test drive would have been d best option. If any of these options u have not tried don't worry. it's fine. let me tell dat u have really made a good choice. The looks of dis car is modern, elegant and striking.
Old Jul 16, 2012 | 06:07 AM
No this isn't normal its sounds like its in limp home mode which is a common problem with TDI's.
Check that all the small vacuum pipes and connections are in good condition.
You could also do with finding someone with VAG-COM\VCDS to so an Autoscan for you. If you live in the States then I believe AutoZone will do you a free scan in the hope you buy something of them.
If anyone does a scan for you we need the error codes posting.
jimmy_kbh
Aug 21, 2011 09:27 PM
mamboo
Apr 27, 2010 03:50 AM
FLAT_ERIC
May 28, 2007 12:31 AM
FLAT_ERIC
May 27, 2007 08:41 PM
fernan8925
Jul 18, 2006 06:23 PM
