Heating Vent Routing - 96 Jetta GL 4cyl 2.0 litre
Old Nov 20, 2010 | 09:04 AM
RadioMill's Avatar
Default Heating Vent Routing - 96 Jetta GL 4cyl 2.0 litre
Hello esteemed and enlightened VW forum readers,
I have a 96 Jetta GL and am currently experiencing problems switching the heater air flow to the "feet" vent. On the 96 Jetta, there are 3 ***** for adjusting heat and a/c routing and temp. The first (far left) ****, adjusts the air volume 1 through 4. The second adjusts temperature, and the 3rd adjusts venting. This third switch is the issue. The first setting (when the **** is turned fully clockwise) vents the airflow to the windshield defrost. The second, one click counter, adjusts the flow to the feet. The problem is, when I turn the switch to the "feet" selection, the flow remains on the windshield defrost. If I turn it to the next setting past feet, there is airflow from the front vents, but not from the feet vent. Basically, something has happened and I can no longer get the venting to the feet selection, but all the other selections work fine. Also, the switch feels loose and turns fairly easily whereas before there was tension in the switch, I believe the venting is controlled by a cable connected to the switch. Is this an easy fix? How do I get at the cable to re-connect it or adjust it? Thank you for the input.
RM
JFout
Feb 7, 2012 12:38 AM
PlywoodD
Jul 13, 2011 06:15 PM
Fraschetti
Dec 5, 2010 10:08 PM
vwgolfdriver
Jul 12, 2009 01:11 PM
xmoex
Feb 9, 2009 01:10 PM
