HEAT PROBLEM
Hey its me again ok so I spent another day freezing my A@# off drivng my car. I tried everything that everyone tried helping me with so far. Thanks alot for the replys btw. Ok I tried the key switch and also made sure the connections were touching behind the actual ****. All the fuses are fine also. Any ideas what I should do next????? Please I got nothing coming out of the vents at all.Thanks for the help.
ORIGINAL: Jrailer
hit the back f the blower motor
it is under the glove box sometimes you can knock the brushes loose and it will work for a bit
I have a '95 GL also, and my book says that it's fuse #7 (from left). It's a 20 amp. I can't find a relay specific to the blower. The closest would have to be the A/C relay-(?)
Also, there is supposed to be a blower motor resistor right by the blower motor. That could be what you are looking for.
viggo olesen
Mar 7, 2016 07:26 PM
