gas mileage
Old Apr 4, 2008 | 09:38 AM
lavelle_04's Avatar
Default gas mileage
got a 2000 jetta gls with the 2.0 and auto transmission.when i drive down freeway, im running 3400 rpms at 75 mph. this is why i am only getting 24-25 mpg. does the jetta not have a 5th gear is there anything i can do to bump the mpg up? thanks
Old Apr 4, 2008 | 08:33 PM
Jrailer's Avatar
Default RE: gas mileage
not much you can do
my sons beetle is the same way it would be nice if they put an overdrive in them you would up the mpg a ton
Old Apr 6, 2008 | 06:34 PM
woody1's Avatar
Member
2001 jetta same friggin thing[:@]
Old Apr 8, 2008 | 03:36 PM
classic4x4's Avatar
You might want to check into a cold air intake, they help sometimes. Also, check the spark plug gaps and overall condition, wires and such. Bad spark plugs can be the cause of poor fuel mileage. Also other routine maintenance things like fuel filter, air filter, PVC valve, etc. They all add up.
Kyo_clone
Apr 29, 2008 09:45 PM
Schmitty
Apr 28, 2008 08:19 PM
hunwicks01
Sep 27, 2007 05:01 PM
Tater
Mar 2, 2007 12:09 AM
CB 71
Jun 18, 2006 09:37 PM
