EPC light help
Hello everyone. My 2001 Jetta has an EPC light on. As well as the ASR light. Along with that I have codes 0102, 0343, and 1142. Before I go throwing parts at this thing, could one problem be causing the other? Do I have a computer problem causing the codes, or could the codes be causing the EPC light? I have tried to clean the MAF to no luck. Looks like ill be buying a new one if I have too. Any help is appreciated.
Originally Posted by DBirdsong
(Post 65480)
Hello everyone. My 2001 Jetta has an EPC light on. As well as the ASR light. Along with that I have codes 0102, 0343, and 1142. Before I go throwing parts at this thing, could one problem be causing the other? Do I have a computer problem causing the codes,.
What did you use to get those error codes a generic scanner or VAG-COM\VCDS? |
While using a generic code scanner the codes P0102 Mass Air Flow sensor and P0343 Cam Position sensor have been replaced. No more CEL lights, which in turn I have no ECP or ASR light either. Now on to why I have no power to the A/C compressor.
VAG Error Code: 16486/000258 |
