Engine light on
Old Jul 14, 2008 | 02:27 PM
jettaboy's Avatar
Default Engine light on
Hey, what's the deal with the engine light on Jettas? I bought my '01 last year and it came on shortly there after, it's been on ever since. My mechanic here in NYC says there's nothing wrong that it's a VW problem. I've started to check around the web at various VW friendly sites and I notice this is a wide spread issue. Now it's a big problem 'cause I can't get through NY emmisions tests and it's starting to look expensive. Any advice would be greatly appreciated.
Old Jul 14, 2008 | 07:01 PM
racerx002's Avatar
Default RE: Engine light on
First, get a new mechanic. Then go get a DTC scanner for $60. I'm sure it's an O2 sensor.
Old Jul 14, 2008 | 08:07 PM
Jrailer's Avatar
it is on for a problem not to just open the hood to see if the engine is still there. like racer said get someone that knows what they are doing or get the code numbers from him and post them here and we can help
Old Jul 20, 2008 | 09:14 PM
woody1's Avatar
Member
not that i think its the same problum but every time it rains an i hit a puddel the air pump picks up water and it gets into the sensor and throws a code.
if you dont want to buy a scanner usaly the auto parts store( at lest by my house)will lend it to you. but thats michigan, idont know about new york
Old Jul 27, 2008 | 03:37 PM
jettaboy's Avatar
Thanks to all who replied, I willheed all the advice and get to work!
Twoods12
Nov 19, 2010 07:55 AM
lilngineer
May 2, 2008 07:57 PM
lilngineer
May 2, 2008 09:42 AM
drioux
Apr 1, 2008 12:47 PM
surf3184
Sep 18, 2007 09:04 PM
