Clutch line leaks, please help!
Old Nov 20, 2006 | 09:41 PM
bkrahmer's Avatar
Default Clutch line leaks, please help!
A couple weeks ago, I went around a corner, went to shift, and couldn't shift into any gear. Came to a stop, and the pedal sunk to the floor and I had to pull it back up. A technician I talked to suggested it was probably the clutch master cylinder. I bought a supposedly OEM replacement made by FTE.
I got the new cylinder in, hooked up the lines, started to bleed it, and fluid starts running out of the thing whenever you press down the pedal. I took it back out, compared the old to the new, and nothing seems to be wrong with the master cylinder. I started looking at the black plastic clip that goes onto the end of the line, and it doesn't make sense to me. I cannot see what keeps the fluid from leaking between the plastic clip and the hydraulic line. I have the o-ring in the groove of the plastic clip which keeps the fluid from running around the outside of the clip.
Can anybody please help me? I took the master cylinder and the clip to every shop in town, and they didnt' have any ideas. My last option is to have the car towed 90 miles to the nearest dealer. I talked to the dealer on the phone, and they weren't much help.
Old Nov 21, 2006 | 11:36 PM
bkrahmer's Avatar
Default RE: Clutch line leaks, please help!
Here are some pictures: http://www.krahmer.com/clutch_line.html
Still looking for answer...
thanks
GTIinNC
Mar 7, 2016 08:12 AM
heavenly_blade101
May 29, 2008 07:52 AM
evildicoball
Dec 27, 2006 08:58 PM
GTIinNC
Nov 15, 2006 04:51 PM
rhoman
Jun 28, 2006 08:54 PM
