check engine light
Old Aug 14, 2014 | 03:56 AM
Rob7's Avatar
Question check engine light
I need "advice." My 2013 VW Jetta GLI's "check engine light" came "on." I think came on because I haven't been in to service it when it hit 10,000 miles. It was already serviced at 8,800 miles, so I ignored the "Service Now" "message. I think that ignoring this has caused the car's computer to make the "check engine light" to come "on." In any event, I think if I reset it and it stays off, then problem "solved." If it comes back on, then I have other engine "issues." Does anyone have any suggestions? Also, where is the fuse located?
Old Aug 14, 2014 | 05:46 AM
Welcome to the forum Rob. Name:  VWwelcome.gif
The engine check light (CEL/MIL) is independent of the service light. If its still under warranty as regards the mileage take it into a dealer to be diagnosed and ask them for the error codes found.
You might be able to reset the service light in the MFD settings I can.
Post moved to the correct section.
Twoods12
Nov 19, 2010 07:55 AM
lilngineer
May 2, 2008 09:42 AM
drioux
Apr 1, 2008 12:47 PM
magea
Oct 18, 2007 08:12 PM
magea
Oct 8, 2007 10:55 PM
