automatic tranmission problem
Old May 20, 2006 | 03:30 PM
rusky's Avatar
Default automatic tranmission problem
i got a 99 jetta gls form the aution, has a 2.0 engine. when i first took it out for a spin the gears shifted hard and it jerked when i put in drive or reverse. so i knew it had to to be the fluid. so i drained it. it was black. so i fulled it up with. but still has the same problem. then i filled it up with some more because it was low. it drives better but the fluid is dark red. and suggestings
Old May 20, 2006 | 05:24 PM
bagel's Avatar
Default RE: automatic tranmission problem
what kind of transmission fluid did you use? You might have to flush your tranny for a bit, whoever had the car prolly didn't take care of it.
Old May 20, 2006 | 08:47 PM
p_mister's Avatar
pull the whole tranny pan and clean it out really good. and then go from there.
tony
updog23
Apr 14, 2012 03:43 PM
majidmast
Jul 28, 2011 01:27 PM
00Beetle
Nov 28, 2010 10:37 AM
Kevin
Aug 10, 2009 12:49 PM
V DubScrub
Apr 30, 2007 10:03 PM
