anti theft issues
Old Nov 28, 2008 | 05:15 PM
sc00byd0034's Avatar
Default anti theft issues
i just got finished putting a remote starter in my 2001 jetta 2.0 w/o power windows and it is being weird. it will start fine with the key and when i shut it off it will start with the remote starter as long as i don't wait more than like 20 seconds after i turned it off with the key. but if i wait a while and try the remote starter it turns over but it doesn't stay running and there is a light on the dash that is the oudies line of a car with a key in it which i am assuming that it is for the anti theft. i got a dei 556uw for it and i put the valet key in there. is it not sencing the key in the box or is there some kinda wire i need to hok up so that is thinks that there is a key in the ignition or something. any help would be great
Old Nov 28, 2008 | 07:02 PM
AusLiebeZumAutomobil's Avatar
Default RE: anti theft issues
You probably wired it the wrong way. That's the right VAT Bypass module for that car. I'd check directed electronics website for a proper wiring diagram.
Old Nov 29, 2008 | 07:03 AM
all i did was hook up a power a ground , a negative input from them remote starter which i am guessing turns it on, and then just used a ring to put around the ignition switch. but i guess i will go mess with the ring. maybe its isn't seeing it
Old Nov 29, 2008 | 05:44 PM
I know there is a lot more to it than that. Maybe it's the remote start you're using if that's all the wiring it came with. We used Viper remote starts/alarm systems.
lilsparrow22
Nov 19, 2014 05:00 PM
drcarl
Nov 12, 2012 04:12 PM
Betterdaze
Sep 10, 2011 03:14 PM
ding
Apr 8, 2011 06:13 AM
Rennfahr
Oct 17, 2007 01:19 PM
