'96 Jetta:Headlights failure(low lights) fuses not blown..
HELP!!
Low lights worked before I went into the store- 30 min later when I started the car- both normal driving lights failed to turn on. Highlights still work. A mechanic friend had only enough time to check the fuses- informed me that there is seperate fuses for each side- and that both fuses were fine. So... Now what?? Please respond ASAP as I'm blinding everyone when I drive at night!!! And I'm worried the highlights will suddenly die as well. Thank you!!!! __________________________________________________ ___________________ I live in Hawaii- warm weather- hasn't over heated since I got it used- 4 months ago. however- I had a problem a week earlier starting it after splashing just a little bit of water on the engine when I was topping off the radi. resvr. Had to let it dry out for about 2 hours. When it did start- a big cloud of white smoke came out of the tail pipe. I figure if it was somehow a delayed short in the headlight wiring- it would have tripped the fuses right? and effected more than just the low lights...? _______________________________________________ ALSO>>>> [ul][*]ChkEng light has been on since I bought it- the previous owner covered it with black tape.[*]Occasionally.. when you unlock the doors from the drivers side- one or all the windows go down part way. [/ul][ul][*]The friend who found the car for me reccomended that I do a heater bypass to prevent the motor from blowing...Is this a known problem for this car? I have the parts.. I just hate to loose the ability to heat the car if I don't have to...[/ul] thank you Janna |
Did you get this problem solved?
What was the solution? I just ran into teh same thing on my 2001 Jetta TDI: The low-beam lights don't work. The high beams and marker lights work fine, and all the fuses are good. This just started, and the low-beam headlights wer fine until I tried to use them tonight.
Thanks. |
Your bulbs need to be replaced.
Sure enough... bulbs were bad
You were correct. After pulling out and gutting the 173 relay (to try and bypass the DRL circuit), I still had no lights. In desperation, I finally checked the bulbs and BAM, I felt like an idiot when I saw both low-beam filaments burned through.
At that moment my head actually turned into a donkey head like in the Looney Tunes cartoons. I brayed loudly, fell 300 feet off a cliff, and landed next to a plate of ACME bird-seed. Then I got new bulbs and all is well. At least I don't have Daytime Running Lights anymore. And all it cost me was a day of f*#&ing around with my car showing off my crappy troubleshooting skills. They had both failed at once, and I assumed the chances of simultaneous bulb-failure were negligible. Stupid me. Anyway, thanks for the help! |
It is strange they blew out at the same time. It seems like such a surge of power would blow a fuse.
Same Problem
So what's the solution?
I have 2001 Jetta with the same problem Fuse OK, Relay OK, now what???? please help Richard |
So, both beams blow out?
I check relays, fuses, you think may be the switch? |
