95 jetta 2.0 couple of problems i have
Old Aug 7, 2009 | 04:52 PM
stock95jetta's Avatar
Default 95 jetta 2.0 couple of problems i have
hi, everybody any help would help thanks
i have 95 jetta 2.0 i have the oil pressure light on blinking all the time
i looked at the Clinton manual this is what it said
low oil lever it has the right amount of oil
idle rpm below spec it idles at 800-900 rpms which is right
worning engine bearing or oil pump i still have to chk the pump and i dont think it is the bearing it has 67,xxx miles but ill check that also
oil pick-up strainer clogged i still need to check that also
oil pressure relief valve defective where is this at?
Is there any think im missing if so plz mention it on this thread any help plz
plus where can i check to see the the oil presurre with a gauge?
also how can i adjust the clutch cable
thanks
bernardo
RemyMartin
Jul 24, 2009 03:13 PM
Hproduction38
May 30, 2009 09:21 AM
Sandrailvw
Oct 16, 2007 09:31 PM
Josh
May 22, 2007 09:03 PM
jokerjosh
Feb 19, 2006 08:28 PM
