87 jetta stuttering when warm, turnoff & backon, ok for 1/2 mile then stutters again?
Whats up guys,,
Well like i said i have an 1987 jetta gl. And the car will start up fine and run ok for a while, then when it gets warm, it starts skipping under a load and backfires and pops sometimes.
But if i turn the ignition off and right back on while going down the road it will turn right back on and run fine for another 1/2 mile or so, then it starts doing the same thing.
It will do this as many time as your cycle the engine. I know this because it started happening when i was in the middle of a 200 mile drive and i made it about a 125 miles turning the car off and back on again every mile
Thanks in advance guys,
Patrick-
Patrick-
You don't say if its a petrol or diesel Jetta?
Well it hard to diagnose car problems over the web as you can imagine. Do you have any engine (Malfunction Indicator Lamp (MIL)) lights lit on the dash board?
Even if they aren't lit the easiest way to diagnose the fault on a VAG vehicle is find someone with VAG-COM\VCDS to do an Autoscan to find the error codes. If you live in the States I believe that AutoZone, PepBoyz, Advance Auto will do a free scan with the hope that you buy something of them.
True VAG-COM came out in 1994 but you would need the 2x2 adaptor cable for VCDS but that is only shown back to 1991 because it older.
VCDS Compatibility Charts
napleswebguy
Oct 3, 2012 04:23 AM
jpneilsonUSCG21
May 19, 2011 11:08 PM
Prosequimur
Aug 21, 2009 03:57 AM
