2016 Jetta 1.4 turbo problem
Old Apr 25, 2019 | 12:26 PM
Kallex's Avatar
Default 2016 Jetta 1.4 turbo problem
New member here, not sure if this issue had been posted before or not, just trying to get some insight to my current situation(not mechanically inclined at all).Noticed I had lost all boost on my Jetta one day while driving, epc light came on as well. Took my car to the shop for a diagnostic test, they told me the turbo booster lever was broke and I needed to replace my turbo. Said it would be around 2000+ to fix my car. I’ve tried researching and can’t find anything on the turbo booster lever. Any information would be greatly appreciated.
Old Apr 26, 2019 | 04:20 AM
Which scanner did this garage use a generic scanner or VAG-COM\VCDS?
Tim Heasley
Mar 23, 2020 07:32 AM
Cabriojoe2.0
Jan 20, 2020 08:28 AM
curtis79
Jul 23, 2019 08:39 AM
loggerman
Mar 1, 2018 07:43 AM
SouthernGent
Dec 16, 2014 07:46 PM
