2004 Jetta GLS Low Voltage codes
Old Sep 20, 2014 | 10:21 AM
Edziu63's Avatar
Default 2004 Jetta GLS Low Voltage codes
My 2004 2.0l wont start but cranks, I scanned it and got these codes,
p0264, p0445, p0261, p0270, p0267, p2401, p2257, p0043, p0037. Any thoughts as to what could be wrong....
Old Sep 20, 2014 | 06:55 PM
VAG Error Code: 16648
EOBD II Error Code: P0264
Fault Location:
Injector 2 (N31) - Circuit Low/Short Circuit to Earth
Possible Cause:
Engine Misfire.
Engine Run Rough.
Low MPG.
Fuse(s).
Wiring/Connector(s) short to earth.
Injector 2 (N31).
Engine Control Module (ECM).
Tech Notes:
Clogged or partially clogged fuel injector can cause this code. Start by performing an injector flush before replacing the injector.
Description:
Code P0264 is triggered when the Engine Control Module (ECM) detects a low voltage in the Fuel Injector 2 Circuit. During normal conditions the Engine Control Module (ECM) turns the Fuel Injectors ON and OFF in the Fuel Injection System.
VAG Error Code: 16829
EOBD II Error Code: P0445
Fault Location:
Evaporative Emission (EVAP) Purge Solenoid (N80) - Short Circuit
Possible Cause:
Wiring/Connector(s) short circuit.
Evaporative Emission (EVAP) Purge Solenoid (N80).
When is the code detected?:
An excessively high voltage signal is sent to Engine Control Module (ECM) through the valve.
Description:
The Evaporative Emission (EVAP) System Canister Purge Volume Control Solenoid Valve controls flow rate of fuel vapour from the Evaporative Emission (EVAP) System canister. The opening of the vapour by-pass passage in the Evaporative Emission (EVAP) System canister purge volume control solenoid valve changes to control the flow rate. The Evaporative Emission (EVAP) System canister purge volume control solenoid valve repeats ON/OFF operation according to the signal sent from the Engine Control Module (ECM). The opening of the valve varies for optimum engine control. The optimum value stored in the Engine Control Module (ECM) is determined by considering various engine conditions. When the engine is operating, the flow rate of fuel vapour from the Evaporative Emission (EVAP) System canister is regulated as the air flow changes. The EVAP canister purge volume control solenoid valve uses a ON/OFF duty to control the flow rate of fuel vapour from the EVAP canister.
The EVAP canister purge volume control solenoid valve is moved by ON/OFF pulses from the Engine Control Module (ECM). The longer the ON pulse, the greater the amount of fuel vapour that will flow through the valve.
VAG Error Code: 16645
EOBD II Error Code: P0261
Fault Location:
Injector 1 (N30) - Circuit Low/Short Circuit to Earth
Possible Cause:
Engine Misfire.
Engine Run Rough.
Low MPG.
Fuse(s).
Injector 1 (N30).
Code P0261 is triggered when the Engine Control Module (ECM) detects a low voltage in the Fuel Injector 1 Circuit. During normal conditions the Engine Control Module (ECM) turns the Fuel Injectors ON and OFF in the Fuel Injection System.
VAG Error Code: 16654
EOBD II Error Code: P0270
Fault Location:
Injector 4 (N33) - Circuit Low/Short Circuit to Earth
Possible Cause:
Engine Misfire.
Engine Run Rough.
Low MPG.
Fuse(s).
Injector 4 (N33).
Tech Notes:
Description:
Code P0270 is triggered when the Engine Control Module (ECM) detects a low voltage in the Fuel Injector 4 Circuit. During normal conditions the Engine Control Module (ECM) turns the Fuel Injectors ON and OFF in the Fuel Injection System.
VAG Error Code: 16651
EOBD II Error Code: P0267
Fault Location:
Injector 3 (N32) - Circuit Low/Short Circuit to Earth
Possible Cause:
Engine Misfire.
Engine Run Rough.
Low MPG.
Fuse(s).
Injector 3 (N32).
Tech Notes:
Description:
Code P0267 is triggered when the Engine Control Module (ECM) detects a low voltage in the Fuel Injector 3 Circuit. During normal conditions the Engine Control Module (ECM) turns the Fuel Injectors ON and OFF in the Fuel Injection System.
EOBD II Error Code: P2401
Fault Location:
Evaporative Emission (EVAP) Leak Detection Pump, Control - Circuit Low
Possible Cause:
Fuse(s).
Evaporative Emission (EVAP) leak detection pump.
Possible Solutions:
Check/Replace Fuse(s).
EOBD II Error Code: P2257
Fault Location:
Secondary Air Injection (AIR) System, Control 'A' - Circuit Low
Possible Cause:
Fuse(s).
Secondary air injection (AIR) pump relay (J229).
Secondary air injection (AIR) pump.
Secondary air injection (AIR) solenoid.
Possible Solutions:
VAG Error Code: 16427
EOBD II Error Code: P0043
Fault Location:
Heated Oxygen Sensor (HO2S) 3, Bank 1/Oxygen (Lambda) Sensor (O2S) 3, Bank 1, Heater Control - Circuit Low
Possible Cause:
Fuse(s).
Heated Oxygen Sensor (HO2S) 3/Oxygen (Lambda) Sensor (O2S) 3.
Possible Solutions:
Check Heated Oxygen Sensor (HO2S) 3, Bank 1/Oxygen (Lambda) Sensor (O2S) 3, Bank 1 heating circuit.
Check/Replace Heated Oxygen Sensor (HO2S) 3, Bank 1/Oxygen (Lambda) Sensor (O2S) 3, Bank 1.
Tech Notes:
The code means that there is a problem with the heater element circuit of the heated oxygen sensor. Water getting inside the heated oxygen sensor connector can caused the heated oxygen sensor fuse to blow, which is a very common problem for this type codes. Before replacing the sensor, check for the condition of the heated oxygen sensor fuse and connector(s).
The P0043 is set when the Engine Control Module (ECM) detects an excessively low voltage through the heated oxygen sensor heater circuit.
Description:
Oxygen Sensors (O2S) or Heated Oxygen Sensors (HO2S) need to reach a minimum operating temperature of 750 degrees F to produce an accurate voltage signal. The faster the heated oxygen sensor reaches that temperature the faster the sensor will start sending an accurate signal to the Engine Control Module (ECM).
In order to achieve the require temperature, a heater element is included inside the heated oxygen sensor. The Engine Control Module (ECM) controls the heated oxygen sensor heater element based on signals from the engine coolant temperature and engine load. The Engine Control Module (ECM) controls the heater element circuit by allowing current flow to ground.
The Engine Control Module (ECM) monitors the voltage signal received through the heater element circuit and determines the state of the circuit by comparing the voltage detected with the factory specifications.
VAG Error Code: 16421
EOBD II Error Code: P0037
Fault Location:
Heated Oxygen Sensor (HO2S) 2 (G130), Bank 1, Heater Control - Circuit Low
Possible Cause:
Fuse(s).
Heated Oxygen Sensor (HO2S) 2 (G130).
Possible Solutions:
Check Heated Oxygen Sensor (HO2S) 2 (G130), Bank 1 heating circuit.
Heater voltage < 3.00 V.
Tech Notes:
The P0037 is set when the Engine Control Module (ECM) detects an excessively low voltage through the heated oxygen sensor heater circuit.
Description:
The P0037 is set when the ECM detects an excessively low voltage through the heated oxygen sensor heater circuit.
Description:
In order to achieve the require temperature, a heater element is included inside the heated oxygen sensor. The ECM controls the heated oxygen sensor heater element based on signals from the engine coolant temperature and engine load. The ECM controls the heater element circuit by allowing current flow to ground.
The ECM monitors the voltage signal received through the heater element circuit and determines the state of the circuit by comparing the voltage detected with the factory specifications.
alucasrn
May 11, 2011 08:00 PM
Apr 18, 2011 11:25 PM
Jan 26, 2011 11:50 PM
racerx002
Feb 7, 2009 12:46 PM
disreef
Oct 26, 2007 04:24 PM
