2002 2.0L check engine light??
Old Jan 11, 2011 | 09:04 PM
dts01's Avatar
Question 2002 2.0L check engine light??
Hello, Im new here I just got a 2002 Jetta with a 2.0l automatic about a week ago and the check engine light came on so I took it to autozone to get the code read and it is a P1296, so I replaced the engine coolant temperature sensor and seal and the motor won't warm up to 190 and the check engine light is still on, any info would help a ton, thanks
Old Jan 12, 2011 | 02:32 AM
elrocco88's Avatar
Have you checked, if you got more codes?? Your thermostat, might be getting stuck. Have you replaced it before??
Old Jan 12, 2011 | 08:16 AM
dts01's Avatar
it was just the p1296 code that showed up and I have replaced them in other vehicles but not the jetta, thanks for the response, i was thinkin the thermostat was bad to but the car doesn't get up to the operating temp, could the thermostat cause that also? thanks again
Twoods12
Nov 19, 2010 07:55 AM
lilngineer
May 2, 2008 09:42 AM
drioux
Apr 1, 2008 12:47 PM
magea
Oct 18, 2007 08:12 PM
magea
Oct 8, 2007 10:55 PM
