2002 2.0L check engine light??
Hello, Im new here I just got a 2002 Jetta with a 2.0l automatic about a week ago and the check engine light came on so I took it to autozone to get the code read and it is a P1296, so I replaced the engine coolant temperature sensor and seal and the motor won't warm up to 190 and the check engine light is still on, any info would help a ton, thanks
Have you checked, if you got more codes?? Your thermostat, might be getting stuck. Have you replaced it before??
it was just the p1296 code that showed up and I have replaced them in other vehicles but not the jetta, thanks for the response, i was thinkin the thermostat was bad to but the car doesn't get up to the operating temp, could the thermostat cause that also? thanks again
