-   -   2001 jetta vr6 noise/vibration HELP ! (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/2001-jetta-vr6-noise-vibration-help-6682/)
dozanti Oct 22, 2008 07:46 AM
Here is the problem:
vibration and noise from 900rpm-1500rpm
get on it a little and it disapears until 3000-3500rpm
im aware of the famous chain tensionor on these vr6 motors breaking and causing slack in the chain and vibration/noise. How ever it is not as consistant or noticable as many vid clips and audio clips i have seen/heard or described as bad.
so i noticed my motor isnt exactly level....... could this vibration be caused by a broken motor mount? with the noise to follow.... also could it be a belt tensioner and timing belt (i know the belt wont make noice but the pulley and tensior may cause it) .... also it seems to be coming from passenger side of motor ... and the timing chains are on the driver side......im stumped, i just bought the car too (first VW)
also its a 5 speed, if thats another factor for figuring out my problem ... THANKS !!!!
dozanti Oct 22, 2008 07:49 AM
RE: 2001 jetta vr6 noise/vibration HELP !
also i meant belt tensioner and and serpantine belt ... sorry .... because i know they have a two chain timing system and in order to do so i need to remove the trans ...... thanks for listening !
Jrailer Oct 22, 2008 08:46 AM
put a jack under the motor and lift it up level and see if it goes away
dozanti Oct 23, 2008 09:48 PM
thanks guys, i really appreciate it.... im going to look at it this weekend when i get a minute and while im tuning it up
dubalicious Oct 24, 2008 02:26 PM
also while your tuning it up join *********.******.com :)
