2001 jetta vr6 noise/vibration HELP !
Old Oct 22, 2008 | 07:46 AM
dozanti's Avatar
Member
Default 2001 jetta vr6 noise/vibration HELP !
Here is the problem:
vibration and noise from 900rpm-1500rpm
get on it a little and it disapears until 3000-3500rpm
im aware of the famous chain tensionor on these vr6 motors breaking and causing slack in the chain and vibration/noise. How ever it is not as consistant or noticable as many vid clips and audio clips i have seen/heard or described as bad.
so i noticed my motor isnt exactly level....... could this vibration be caused by a broken motor mount? with the noise to follow.... also could it be a belt tensioner and timing belt (i know the belt wont make noice but the pulley and tensior may cause it) .... also it seems to be coming from passenger side of motor ... and the timing chains are on the driver side......im stumped, i just bought the car too (first VW)
also its a 5 speed, if thats another factor for figuring out my problem ... THANKS !!!!
Old Oct 22, 2008 | 07:49 AM
dozanti's Avatar
Member
Default RE: 2001 jetta vr6 noise/vibration HELP !
also i meant belt tensioner and and serpantine belt ... sorry .... because i know they have a two chain timing system and in order to do so i need to remove the trans ...... thanks for listening !
Old Oct 22, 2008 | 08:46 AM
Jrailer's Avatar
put a jack under the motor and lift it up level and see if it goes away
Old Oct 23, 2008 | 09:48 PM
dozanti's Avatar
Member
thanks guys, i really appreciate it.... im going to look at it this weekend when i get a minute and while im tuning it up
Old Oct 24, 2008 | 02:26 PM
dubalicious's Avatar
also while your tuning it up join *********.******.com
driftwood
Oct 29, 2009 09:12 AM
Micah
Sep 23, 2009 10:24 PM
Matt
Oct 17, 2008 11:11 PM
Matt
Aug 1, 2007 11:06 AM
godoveryou
May 22, 2007 03:07 AM
