2001 Jetta Engine Died
Old Jan 15, 2012 | 04:06 PM
redlight's Avatar
Default 2001 Jetta Engine Died
Driving home last night my 01 jetta, with AZG engine, just stopped running. I noticed that the EPC light came on, I had plenty of battery power. As far as I could tell it sounded like the starter was just spinning and not really turning the engine over. Very hard to hear with all of the freeway noise. If anyone has an idea, please send it! Thanks!
Old Jan 16, 2012 | 04:56 AM
Well thats not normal that the starter sounds as though its spinning but it doesn't turn the engine over. For a pre-engaged starter to spin it as to be engaged in the flywheel ring gear. Remove the starer motor and investigate.
As for why the EPC light came on you need to find someone with VAG-COM to do an Autoscan.
Old Jan 16, 2012 | 12:45 PM
redlight's Avatar
I had the 2001 jetta looked at and the timing belt went out. Mechanic stated there may be other damage such as piston/valve. I'm hoping there will be no other damage?!
ewb727
Apr 17, 2011 12:49 AM
RussT
Mar 28, 2010 11:37 AM
drop_it_like_its_hot
Nov 29, 2006 08:31 PM
dash5
Sep 18, 2006 09:43 PM
genevieved
Sep 9, 2006 05:29 AM
