2000 Jetta trunk stuck closed after using WD-40 on struts....
Old Nov 27, 2006 | 03:56 PM
Jetta2385's Avatar
Default 2000 Jetta trunk stuck closed after using WD-40 on struts....
My 2000 VW Jetta GLS trunk was getting quite hard to lift up and very stiff compared to when I got it in 2002. So, I thought it was a good idea to srap some WD-4O on what i think are the "struts." The arms that connect the trunk door to the actual body of the car. So, after spraying the WD-40 i lifted the trunk up and down a few time and shut it closed. About 4 days later i tried to open it and it is stuck closed. When i press the remote i can hear the motor working except the trunk does not pop open. I tried crawling in the back throught the seats and i removed the carpeting and the lock it now visible. How do i manually get the lock to unlock? Or how can i fix this?
fleminsh
Aug 29, 2011 09:08 AM
graham171057
Nov 20, 2008 02:39 PM
davewillner
Sep 6, 2008 12:52 PM
SVORangerboy
Aug 2, 2007 02:37 PM
blujet
Apr 30, 2006 01:08 AM
