1999 MKIII Jetta VR6 Trans/Clutch Problem
I recently purchased a 1999 Jetta GLX. It's a 5 speed and has about 100,000 miles on it. I bought it, drove it to check it out and then parked it for about a month. When I parked it, it was fine. Now clutch slipping, the gears engaged properly etc... Now the last couple of times I have tried to drive it, it simple will not allow me to shift it into gear no matter what. I can't get reverse,1st or 2nd to get the car moving. As I let the car warm up it seems to get slightly better but definitely not the way it should be. I highly doubt it's a syncro problem because I can't shift into gear even with the engine off. I am guessing the crappy hydraulic cluctch needs to be bled. (I hate hyrdaulic clutches - cables rule!!) - Anyway, I am assuming that's the problem so if anyone has any input or instructions for bleeding the clutch I would be very very appreciative!!
Peace! ChR1s |
RE: 1999 MKIII Jetta VR6 Trans/Clutch Problem
You are starting at exactly where i was thinking to go. I would check clutch fluid levels, hydraulic slave cylinder, and all lines for leaks it sounds like that part is the one malfunctioning.
Are there any lights on the dash now?
LOL njoy this one they are a B%^&$
