-   -   1999 Jetta Front Rt Directional Light (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/1999-jetta-front-rt-directional-light-2607/)
Skumph Mar 1, 2007 03:15 PM
I have a 1999 jetta, front right directional light is not working, how are you supposed to get to it, it is in a very tight spot. I thought it was a bad bulb, but by just pushing on the harness that holds the bulb it comes back on, so the bulb is either loose or the wiring is loose. Either way I am unable to get to it to work on it. Any ideas would be helpful. I wish it were the left one, very easy to work on. Thanks!
Skumph Mar 1, 2007 03:40 PM
RE: 1999 Jetta Front Rt Directional Light
Found the answer to my own question at the following link, with pictures
http://autorepair.about.com/library/a/1f/bl562f.htm
RAC97JETTA Apr 5, 2007 12:03 AM
https://volkswagenforum.com/micons/m13.gifhad the same question on my mind ,thanks for the imfo. cant wait for my service manual to get here . May right fog light was tough enough to change do to the socket was stuck tight.they dont give much room for big hand to do things. But just cant help liking my jetta gt https://volkswagenforum.com/micons/m10.gif. hope you have good luck with your's.
:eek: thank for the info
