1997 Jetta Rattle at 2000 rpm
Old 06-04-2008 | 02:06 PM
k3c4forflife's Avatar
Default 1997 Jetta Rattle at 2000 rpm
Hey all,
I just bought a 1997 Jetta GL 5 speed with 125,000 miles. The car has been well maintained. It's a great car, but I have found that when I shift and the engine is running between 1900-2100 rpm, I get a rumble. The sound comes from underneath the car behind the center armrest (where the middle backseat passenger's feet would rest). I can also hear the sound in 5th gear when the Jetta reaches about 60mph. It isnt coming from up front, which I'm assuming is a good thing. Any ideas where the problem is, how hard is it to fix, and how much do you think it would cost to get it done?
Thanks forany suggestions in advance!
Kevin
Old 07-24-2008 | 09:43 AM
marconious's Avatar
Default RE: 1997 Jetta Rattle at 2000 rpm
Is it the heat shield? I have replaced my heat shield behind my exhaust manifold twice - it's a very poor design
Old 03-22-2009 | 05:27 PM
david2263's Avatar
Originally Posted by k3c4forflife
Hey all,
Kevin
Sounds like the Heat sheild resonating at that RPM. I'm pretty sure theres a heat shield covering the Catalyst ... and its located right where you mentioned. As for how much it costs I'm not too sure... could be as easy as a quick weld??? thats all i know, sorry. Good luck!
jbjeep3
05-28-2013 12:05 PM
detserone
11-10-2011 07:59 PM
scottsjet
02-16-2011 06:10 PM
TechOhSeven
11-22-2006 05:18 PM
Bret
09-01-2006 06:57 PM
Quick Reply: 1997 Jetta Rattle at 2000 rpm
