1997 Jetta Check Engine Light
I have a 1997 VW Jetta and the check engine light is on. I failed the emissions test and the code read that i have an O2 sensor with no activity. I replaced the faulty sensor, but failed emissions again. The code this time read no circuit activity. There was a faulty wire in the circuit, I replaced it and the check engine light turned off. I went to get it tested again, and I failed. The check engine light "forced itself on" (as it said in the report) and the code came up as "no circuit activity" and "system to rich." I have an OBD and I cleared all of the codes before my test, turning the light off, but the light "forced itself on" again causing me to fail. Does anyone have any suggestions?
Twoods12
Nov 19, 2010 07:55 AM
