08 Jetta Fault Code
Post the fault code number and I will tell you more?
You will need to find someone with VAG-COM\VCDS not the cheap ones of fleabay.
VAG Error Code: 02511
Fault Location:
Control Module for Seat Occupied Recognition (J706) - No or Incorrect Basic Setting/Adaptation
Possible Cause:
Function Limitation.
Airbag Warning Light active.
Basic Setting Not Performed.
Possible Solutions:
Perform Basic Setting.
Special Notes:
When found in Audi A3 (8P): Airbag 9.41, perform Basic Setting.
When found in Audi A4 (8E): Airbag 9.41, perform Basic Setting.
When found in Audi A6 (4F): Airbag, perform Basic Setting.
When found in Audi A8 (4E): Airbag, perform Basic Setting.
When found in Audi Q7 (4L): Airbag, perform Basic Setting.
When found in VW Eos (1F): Airbag perform Basic Setting
When found in VW Golf/Jetta/Bora V (1K/5M): Airbag, perform Basic Setting.
When found in VW New Beetle/Cabriolet (1C/1Y/9C): Airbag, perform Basic Setting.
When found in VW Passat (3C): Airbag, perform Basic Setting.
When found in VW Phaeton (3D): Airbag, perform Basic Setting.
When found in VW Touareg (7L): Airbag, perform Basic Setting.
Fault Location:
Control Module for Seat Occupied Recognition (J706) - Defective\Implausible Signal
Possible Cause:
Wiring/Connector(s) from/to Control Module for Seat Occupied Recognition (J706) faulty.
Possible Solutions:
Check Wiring/Connector(s) from/to Control Module for Seat Occupied Recognition (J706).
Check Measuring Value Blocks (MVB) for Seat Occupation Pressure Sensor (G452).
Check/Replace Control Module for Seat Occupied Recognition (J706).
Special Notes:
en 02511 - Control Module for Seat Occupied Recognition (J706) 014 - Defective is stored in the NAR (North American Region):
2004 -> 2008 New Beetle and New Beetle Convertible (1C/1Y).
2005 -> 2008 Jetta (1K).
2006 -> 2008 Passat and Passat Wagon (3C).
2007 -> 2008 Eos, Gti, Rabbit, and R32 (1K).
Please see TSB # 01-08-07 or 2010347. This TSB covers the dealer updating of the PODS module and should be checked or completed prior to replacing the module.
Fault Location:
Possible Cause:
Possible Solutions:
Special Notes:
Fault Location:
Possible Cause:
Possible Solutions:
Special Notes:
